Topic: Pro pricing
Hi, I have a Traktor audio 6 with the traktor timecode vinyl and it’s working well with VDJ. I can only use it for 10mins before it’s prompting to upgrade.
I can’t see Traktor Audio 6 available for home plus pricing? Is my only option to purchase the infinity?
Posted Wed 31 Jan 24 @ 12:18 am
It's not the soundcard itself.
It's your sound configuration.
"External mixer" audio configuration (separate output per deck) requires a PRO license, yes.
Not enough:
Analog Mixer (sound config)
Only timecode needs the pro ! ?
Hi yes so my setup is an old analog mixer using the Traktor Audio 6 with 2 turntables.
I see I can purchase the Home Plus for “analog Mixer” but will that enable me to use timecode vinyl? From what I can tell if I want to use timecode vinyl the only way it to purchase the pro infinity is that right?
For using timecode you indeed need a pro license.
With the Pro version, I am currently doing the monthly subscription. If I purchase the software out right, will the software be updated continuously also?
Yes it will.
