At the moment in the Track cleaner, we have Reverse and Mute Vocal, the latter of which was made possible with stems acapella usage.
Given that currently, we can use any effect fader effect with any stem type we want while playing a song regularly, this ability could probably be used to expand the censoring function even further, either replacing the vocal section with the same vocal section having an effect applied, or (for effects with trailing/residual audio) by applying the effect, post fader, and dropping the volume of the acapella stem.
At the very least, could the following options be added:
The latter ones, which are BPM and Beat length parameter sensitive, could have an adjustment parameter for tuning them how we would like.
- Reverse Vocal
This is cleaner than reversing the entire song - Echo Out Vocal
- Beatslice Vocal
- Brake Vocal
Posted Mon 15 Jan 24 @ 6:50 pm
