Topic: Pitch auto sets between decks
I updated VDJ and now the pitch automatically sets itself between decks. I know this is a simple fix, but i just can't figure it out.
Posted Fri 05 Jan 24 @ 3:59 pm
It's most likely auto bpm match
But you should probably go trough all the auto options, and check that they are set to you liking
