It would be really nice to have a setting that keeps cues, loops etc. where they are in relation to the beatgrid when adjusting it. Sometimes I'll realize a track doesn't hit quite right when jumping to a cue and adjust the beatgrid, but then all the cues have to be moved manually as well.
I tried playing with shift_all_cues but it doesn't use the same units as adjust_cbg, so you can't move both in ms, or both in beats, or in percentages, meaning you can't adjust both at the same time.
Alternatively, allowing for those units to be used in both commands instead of a new global setting would work too.
Posted Fri 22 Dec 23 @ 3:59 am
shift_all_cues should already accept milliseconds as parameter, so
"shift_all_cues +100ms" should work
Posted Fri 22 Dec 23 @ 6:32 am
But adjust_cbg doesn't, so you have to do them separately
(unless I'm doing it wrong; when I try to do it using milliseconds this happens https://www.youtube.com/watch?v=IbqSQrv5ZZA )
Posted Fri 22 Dec 23 @ 7:16 am
Ah, indeed a bug with adjust_cbg when using milliseconds, will fix
Posted Fri 22 Dec 23 @ 8:35 am
Good to know!
Thank you for your work o7 I've been having a blast with Virtual DJ so far!
Posted Fri 22 Dec 23 @ 9:58 am
