I just downgraded from version b7746 to b7692 (because a sudden graphic bug with my haunted pro skin).
Therefore I deinstalled and than installed the old version.
Now in VDJ none of my skins and mappings are to be found.
The folder "VirtualDJ" in user data folder is untouched. There is everything, but not in the prog...
In this folder are skins that are not showen in the prog.
As if there where an old hidden folder without anything that VDJ now uses.
Why VDJ doesn´t see my "VirtualDJ"-folder
Please help, I have gigs the next days and need my stuff...
Posted Wed 01 Nov 23 @ 1:13 pm
The home folder is in a new location for new installs. Click the cog at the bottom right of the settings page and it will open up the new location.
Close VDJ, copy over from the old documents home folder location to overwrite what is in the new one then restart VDJ.
Posted Wed 01 Nov 23 @ 1:16 pm
OMG, KRADCLIFFE, Thank You sooo much.
Everything is at it´s place again.
I´m happy and can concentrate on my work.
Have a nice day and greetings
Sven
Sven
Posted Wed 01 Nov 23 @ 1:47 pm
you can change the InstallationPath
Posted Sat 18 Nov 23 @ 3:18 pm
