Topic: Audio level
I'm using a Roland DJ-707m with VDJ. I just started using Virtual and I'm LOVING it. One thing though, when I play songs in the automix window, when a new song starts playing, it's quite a bit louder than the previous song. Is there a setting to "fix" this? When I'm mixing manually, I'm able to set the level on each track with the trim knobs, but in automix, they seem to default to 12 o'clock and I have to adjust each track on the fly. This defeats the purpose of Automix if I have to babysit it.
Posted Sun 22 Oct 23 @ 12:00 pm
To change the volume you should change either the master volume, or the decks level faders, not the gain knob.
