Hi.
I'm trying to find a script that turns my loop_call+ button into an adjust_cbg +0.01 or adjust beat grid + button and that turns my loop_call- button into an adjust_cbg -0.01 or adjust beat grid - button. I want this action to take place as long as I'm holding down the button. So far the with different scripts I have applied, the action only takes place once the button is released and even with that the beat grid jumps adjust rather than slide adjust. Thanks in advance for help you're able to provide.
Posted Tue 10 Oct 23 @ 5:02 pm
see http://www.virtualdj.com/plugins/index.html?addonid=80408
it will probably have examples you can use.
Posted Tue 10 Oct 23 @ 5:12 pm
This install will have examples of scripts?
Posted Tue 10 Oct 23 @ 5:46 pm
yeah, the padpage does that kind of job, use it as a resource to see how it does it.
Posted Tue 10 Oct 23 @ 5:53 pm
The pad page extension worked. I copied the script from the pad editor and applied it to the assigned button. Thank you.
Posted Tue 10 Oct 23 @ 6:03 pm
part of the intention of a few of my early padpages, a pad page for just beatgrid is excessive, but make it hidden and just use it as a reference then you don't need to remember how it's done.
Posted Tue 10 Oct 23 @ 7:47 pm
