Hello all!
I am relatively new to the program so apologies if this topic is a known issue. I tried looking for something similar but couldn't find a solution to the problem.
So, I have enough songs loaded in Automix and when I try to start it, it just plays the first song on deck 1 and then stops right after it (without loading or playing the next one). The icon for automix is not lit and when you select the dropdown menu there is no tick next to "Start automix".
I played with the settings and the only way I managed to actually blend 2 songs (not more) was to activate the Automix option on 2 decks. Then the icon is active and I can see the tick, BUT it won't play more than 2 songs...
So no matter what I do, the Automix doesn't run as it should for me. Any ideas?
Posted Mon 09 Oct 23 @ 9:06 am
Are you using Tidal streaming?
Posted Mon 09 Oct 23 @ 9:37 am
UPDATE, maybe a few more details.. (@ Kradcliffe, you posted as I was typing)
this may not be related.. but wanted to mention, that as of a week ago, one needs a Tidal HiFi Plus level plan for Automix to work.
here is one of a few threads on the topic, of tracks not loading in Automix with a Non-Tidal PLUS plan.
https://www.virtualdj.com/forums/254798/VirtualDJ_Technical_Support/TIDAL_Tracks_no_longer_load_in_Automix.html
Automix is works flawlessly here. The above is the only idea.
Posted Mon 09 Oct 23 @ 9:45 am
I see. Yes, that solves the issue then.
Thank you much
Thank you much
Posted Mon 09 Oct 23 @ 12:09 pm
