Hello,
My computer was equipped with an RTX 3050 and an Intel Corei5-8400, and VirtualDJ would do 2.0 just fine. I recently upgraded to a Core i9-9900KF, and VirtualDJ no longer thinks my computer is powerful enough to use 2.0 Stems. Respectfully, what gives? This was never the problem with my old CPU, and it shouldn't be a problem now with a better CPU.
Posted Sun 08 Oct 23 @ 7:58 am
What is the GPU in your new computer?
Posted Sun 08 Oct 23 @ 9:36 am
It is the same GPU, the CPU is what changed.
Posted Sun 08 Oct 23 @ 7:47 pm
user27596127 wrote :
Hello,
Check the StemFix choices under performance options make sure it is using the GPU
Posted Mon 09 Oct 23 @ 9:44 am
Yep, its using the GPU... Dunno what's the problem...
Posted Tue 10 Oct 23 @ 5:12 am
Whats the source of the music?
tidal maybe?
tidal maybe?
Posted Tue 10 Oct 23 @ 11:53 am
I use my own downloaded music, that I definitely own and/or bought legally...
Posted Tue 10 Oct 23 @ 7:44 pm
All jokes aside, i use local mp3 files.
Posted Tue 10 Oct 23 @ 7:45 pm
Your stems may be in a new/old location check were the stems folder is set to in setting.
Posted Wed 11 Oct 23 @ 9:28 am
While loading a song, check the tool tip on the cpu meter at the top of the skin to see if it's using the correct GPU, and what the stems speed is.
If it is using the correct GPU, perhaps check if an update for the GPU's drivers is available.
Posted Wed 11 Oct 23 @ 9:35 am
