I'm having trouble setting my crossfader correctly. I have a Rane Four coming from a Numark Platinum NS4FX. The NS4FX was perfect. it was a perfect slope - by the time you go to like 1/4 away from the active platter, it was real low. The Four seems to just drop at the end hard no matter what setting. I tried FULL, SMOOTH, CUT etc. hardly any difference. I tried the linear, quadratic, log one - the linear helped but only a little. Also there's a soft/hard knob on the controller but doesn't do much either. Need help. Want it super rounded and smooth. I don't do scratching or anything so I could care less about the super sloping settings.
Posted Sat 16 Sep 23 @ 11:54 pm
It's a Hardware mixer, the crossfader curve is the dial on the front side of the unit.
Posted Sun 17 Sep 23 @ 12:00 am
Makes sense, but it's lame as hell. Turning it all the way down barely helps but I guess it is as good as it gets.
Posted Sun 17 Sep 23 @ 12:36 am
