I understand that to play time coded vinyl/dvs, u need an interface and whatever. But if I wanted to play just regular vinyl records, would VirtualDJ be able to play/read them without an interface?
Posted Mon 11 Sep 23 @ 12:21 pm
No. How would it be able to "listen" to the sound of your record without an audio interface ?
Posted Mon 11 Sep 23 @ 12:54 pm
To add to what @PhantomDeejay has said, the interfaces have a "Pass Through" mode (a per deck setting), which tells the software to not interpret the signal coming in as DVS, so you can play your regular Vinyl.
Posted Mon 11 Sep 23 @ 1:38 pm
Can i do DVS and with just normal vinyl (but play the songs I have on the computer, not the original vinyl songs) and an interface? Or do I specifically need a time code vinyl
Posted Mon 20 May 24 @ 3:12 pm
No, you can't just play a normal record and have it control the computer. It has to be timecode vinyl.
Posted Mon 20 May 24 @ 3:50 pm
You could also consider Phase DJ.
It will let you user regular normal vinyl, with a gadget on top that tracks your movements on the turntable
and fully supported by VirtualDJ
See here
https://www.phasedj.com/phase-essential/set-up/virtualdj
See here
Posted Mon 20 May 24 @ 3:53 pm
Or just get timecode vinyls as already mentioned. VirtualDJ support several ones, both VirtualDJ own vinyl as well as vinyl from Serato and others that you'll find in local DJ stores
https://virtualdj.com/buy/controlvinyl.html
Posted Mon 20 May 24 @ 3:55 pm
