I am hoping to use vdj with my rev7. I am coming from using my exponentially heavier djms11 with 2 denon sc6000m's.
One of the reasons I want to use vdj is customization. There is a feature I would use on the s11 that I want to implement for my rev7. The deck swap feature. I can get it to "swap from deck 1-4 and 2-3- however I have a big issue. My issue is the move will ignore my decks selected stems. How can I make the swap retain whatever the original deck has?
TIA
TIA
Posted Wed 30 Aug 23 @ 1:01 pm
use this instead
invert_deck
invert_deck
Posted Wed 30 Aug 23 @ 1:07 pm
thanks @locodog -ill give it a go
Posted Thu 07 Sep 23 @ 5:59 pm
