I'm probably overlooking something really obvious here, but if I create a POI at a point in the song with stem_pad 'instrumental' what command do I use to reverse that and enable all stems so the song sounds normal again after the sweary word?
EDIT: Found if you use the same command it reverses the change.
Thanks!
Thanks!
Posted Wed 09 Aug 23 @ 6:32 pm
to turn ON:
stem_pad 'instrumental' on
to turn OFF:
stem_pad 'instrumental' off
UPDATE:
yes the script stem_pad 'instrumental' toggles .. and maybe safer to use above, in the case of jumping to a point in the track, which encounters the second instance .and it actually then removes the vocals, instead of doing nothing.
to turn OFF:
UPDATE:
Posted Wed 09 Aug 23 @ 6:51 pm
You can also use the new Vocal Stem Track Cleaner feature that was recently added:
Posted Wed 09 Aug 23 @ 9:21 pm
