Topic: Stem volume control with external MIDI controller
Hi, as the title says, I would like to control the stems volume with an external MIDI controller. So far I only know that I can do this with the EQ knobs.
But I need the EQ knob functionality...well...for the EQ.
So how can I leave EQs as is and control the stems with an extra controller?
Can anybody please help?
Thank you!
Posted Wed 09 Aug 23 @ 1:23 pm
check the scripts
stem
and
eq_low_freq
Okay, I found it by myself. It is in the equalizer section of the MIDI controls under stem and I have to write the stem type after the word stem.
locodog wrote :
check the scripts
stem
and
eq_low_freq
Thank you! Yes, I have found it now. :)
