Hello,
When I use the echo out effect on deck 1 to transition into a song playing on deck 2, the echo out stops as soon as I switch is all the way over to deck 2 (and vice versa). However, I want it to continue playing so it's more of a smooth transition when I switch songs/decks.
How can I fix this?
Thank you!
How can I fix this?
Thank you!
Posted Tue 18 Jul 23 @ 5:04 pm
check the option for fxProcessing
Posted Tue 18 Jul 23 @ 5:16 pm
Sorry, I'm still new to virtual dj. I checked the options and couldn't find fxprocessing. I also searched for it in the settings. Where exactly is it located?
Thank you
Thank you
Posted Tue 18 Jul 23 @ 5:58 pm
Posted Tue 18 Jul 23 @ 6:08 pm
Thank you. However, I switched it but it's still not working. I even tried restarting and trying again
Posted Tue 18 Jul 23 @ 6:25 pm
Nevermind, it's working now. Thank you!
Posted Tue 18 Jul 23 @ 6:29 pm
