Topic: Phase no Signal after switching to Timecode Vinyl and back
Hi,
my Phase used to work fine with VDJ. I then switched to Serato Timecode. Now I want to switch back to Phase. But there is no Signal detected from VDJ.
I am using an DJM S9. Latest Updates on everything.
Yes, Phase is in the Line Input and there is a fine Signal going into the Mixer on both Channels.
Yes, Relative Mode.
Someone help plz.
Thank you.
EDIT: NEVERMIND, I forgot to switch the Timecode Input in the DJM Utility Software... my bad...
Anyhow, pls work on Phase HID mode ;)
Posted Wed 14 Jun 23 @ 9:05 am
