How can I cycle my_var on the same button.
Hi to you'all.
By this question I also want to share a creativity transition I implement while mixing and hoping someone can grab it and take it to the next level; That is what Djíng is all about. In a controller enviroment this is almost useless, but mixing with a bascic mixer and two turntables with TCV it comes handy.
I have the following script on the keyboard 'Shift+F5' key.
cycle 'BG' 3
So I can cycle between the first 3 beatGrid effect arrangement; we can go to eight you know!
Then to activate the effect I have the following script on the 'F5' key on the Keyboard.
var_equal 'BG' 0 ? deck 1 effect_active 'beat grid' & effect_slider 'beat grid' 1 0 & deck 2 effect_active 'beat grid' & effect_slider 'beat grid' 1 0 :
var_equal 'BG' 1 ? deck 1 effect_active 'beat grid' & effect_slider 'beat grid' 1 0.143 & deck 2 effect_active 'beat grid' & effect_slider 'beat grid' 1 0.143 :
var_equal 'BG' 2 ? deck 1 effect_active 'beat grid' & effect_slider 'beat grid' 1 0.286 & deck 2 effect_active 'beat grid' & effect_slider 'beat grid' 1 0.286 :
This let's me change the BeatGrid Slot on both deck and activate them at the same time.
I use this 1 bar before the Outro kicks in on Deck A at the same time it activates 1 bar before the Mix in on Deck B; there are other variation ofcourse..!
The Question in hand is:
How can I cycle between the beatgrid slots in the same Keyboard press; example pres F5 activates slot 1 press F5 again and it goes the second slot, and again for the third and cycles back to slot 1?
Hi to you'all.
cycle 'BG' 3
Posted Wed 24 May 23 @ 7:37 pm
