Topic: sound seems slower when using bluetooth
Is this a common issue? I just purchased a pair of Yorkville YXL bluetooth loud speakers. When I use VDJ 2023 through bluetooth the sound seems to slow and speed up a bit. Is there anything that can be done??
Thanks folks
Posted Sun 21 May 23 @ 7:01 pm
return them and don't use bluetooth anything. too many latency issues to use them professionally. wired is better but there are MUCH better wireless options than bluetooth
Yes, Solved for 0 latency.. Purchase wireless UHF 2.4ghz XLR's. I use them, and they work perfect.
Bluetooth is not suited for real-time audio. You need instant reaction, I.e. very low latency, orherwise you can't do all the fun stuff such as beatmach, scratch, ..
