Topic: Virtual DJ 2023 General questions
Hi I have a question whether the 2023 version is somewhere available language Polish? I have a Pioneer DDJ FLX-4 controller there is an input for the microphone and an output for the speakers, the sound from the microphone can only be heard from the controller output as I set the sound output to the computer is very squeaky. The controller is connected to the computer using a usb-c cable. In the DJ Serato Pro program, it works normally and I can do so that the sound output is on the computer when the microphone is connected to the controller. Since it works in serato, it should also be possible in Virtual Dj.
Posted Thu 18 May 23 @ 1:53 pm
The whole idea of owning and using a controller is that the sound output comes from the controller. Connect speakers to the master output of the controller.
Posted Thu 18 May 23 @ 9:25 pm
Witam ,jest dostępny język Polski w najnowszym Virtual DJ 2024 ,mam jakieś stare spolszczenie ale nie wszystko przetłumaczy. Jest jakiś plik który można pobrać i wgrać żeby przetłumaczył w 100% Virtual DJ 2024?
Posted Sun 18 Aug 24 @ 6:14 pm
