Topic: Stems 2.0 problem with GTX 1660Ti ?
DJNombePRO InfinityMember since 2009
Hi! I have MSI GS-65 9SD Intel Core i7-9750H/16GB/512GB SSD/GTX 1660Ti/15.6".
Some weeks ago works perfect with stems 2.0 but on last updates stems 2.0 don't work. And sometimes works very slow or very bad.
Posted Mon 08 May 23 @ 9:05 pm
djcelPRO InfinityModeratorMember since 2004
1) Could you share with us a screenshot of your performance tab in the VirtualDJ options?
2) what do you see in the cpu tooltip on the skin?
Posted Tue 09 May 23 @ 7:46 am
I make some changes on performance settings like this attached image and now is working. Thanks.
This is the better settings or I need to change something?
Posted Wed 10 May 23 @ 6:57 pm
