After last update, if stems is used with sampler or other effects there is constant freezing or audio drop out, I'm running Macbook pro with m2 chip, Rane four, and pioneer ddj-xp1... I've tried reinstalling driver and frameware update one the Rane four that didn't change anything and if left unattended for more than two minutes with anything playing I have close and reopen the program . there was no issues before last update.Any help will be greatly appreciated
Posted Sun 07 May 23 @ 2:17 pm
i hade nearly the same issue
i did downgrade to the previous build
just download it and install
Posted Mon 08 May 23 @ 8:43 am
