Topic: Laptop Battery Status
Hi all,
Any way of displaying the laptop battery status in realtime on Virtual DJ 2023 Pro Layout Skin? Somewhere up around the CPU Meter would make sense?
Thanks in adavance!
Posted Wed 19 Apr 23 @ 3:47 pm
It shows when you're running on battery.
I'm not sure why you'd need it when on mains power but it can be done with a skin edit
lines 1608-1893
Cheers for the reply locodog,
The reason I'd like it is because twice recently while gigging I haven't properly pushed the mains adaptor into the laptop properly causing the laptop to die mid gig without any low battery status warning appearing on Virtual DJ. (I'm using an Acer Nitro which plugs at the front of the laptop which causes it to be obscured by the screen so its not noticeable if it isnt plugged in properly) If there was an indicator present I would have a better chance of noticing that it was running on battery and not plugged in properly.
Wouldnt have a clue about skin edits.
Thanks tho.
As above if the indicator isn't showing then you're on mains power.
