I recently bought a new MacBook Air 2020 with a M1 chip. It can flawlessly handle real time stems separating on Serato.
However when I downloaded VDJ it gives me a stems engine error upon startup and is unable to separate stems in real time. My pre saved stems still work fine.
I’m running the most current version of Ventura and the most current version of VDJ. I’ve tried uninstalling and reinstalling with no luck. I’ve toyed with every setting regarding stems performance with no luck there as well.
Any assistance would be awesome.
Posted Tue 18 Apr 23 @ 12:35 pm
A clean installation of Mac OS will probably fix this. Issue is probably when using migration tool
but try to "Disable System Integrity Protection" https://developer.apple.com/documentation/security/disabling_and_enabling_system_integrity_protection
Posted Tue 18 Apr 23 @ 12:42 pm
