Hello this my wish list:
save cue loop in slot & rename by script:
proposition ex: deck 1 loop_save 1 & deck 1 loop_rename_slot 1 "myloopname"
skin deck waveform by stem (with stack view) like in traktor stem
separate: stem fx - vocal mixer fx et stem equalizer. They are all link so you can't apply vocal fx on stem equalizer.
control vst slider parameter by name instead of number
ex: deck 1 effect_slider "mysvt" "parameter_vst_name"
select which deck is in the auto master deck algorithm so you can exclude one deck for example for vsti or an option like deck 1 slave_deck_only
Regards,
Regards,
Posted Sat 15 Apr 23 @ 9:32 am
cue_name 1 "loop" "myname"
should work to set the loop name
Posted Sat 15 Apr 23 @ 9:57 am
It works. Thanks
Posted Sat 15 Apr 23 @ 10:06 am
