I have this problem when pressing jog with Beatlock enabled. (Macbook Pro 2021)
https://www.youtube.com/shorts/HxnuEUHoXYc
Posted Fri 14 Apr 23 @ 5:17 am
Have you tested with other software?
Posted Fri 14 Apr 23 @ 8:03 pm
It only happens with Beatlock active, it's some conflict with the VDJ.
Posted Sat 15 Apr 23 @ 11:57 am
This is the programming of VDJ. Was probably changed from version 7 to 8. Why that is - I have no idea. Can be found quite a bit via google. Mostly it is written it is because of the "Motor"...
Maybe one from VDJ gives your a better answer
Posted Sat 15 Apr 23 @ 5:30 pm
Yes, some engine-related conflict, but I think the VDJ team would easily resolve it.
Posted Mon 17 Apr 23 @ 2:41 am
Does anyone from support have anything I can do or a future update for this "bug"?
Posted Tue 18 Apr 23 @ 9:37 pm
Try it again with the new update...
I test it for a few minutes with my ns7 - works like in old version
Posted Tue 25 Apr 23 @ 7:37 pm
