Hello everyone,
A VDJ user says
I just received my new Denon SC Live4 table, and in standalone mode the talkover works fine but as soon as I plug the laptop with VirtualDj pro license on the table, the talkover doesn't work anymore. Is there any special setting to do in VDj so that it works as in standalone mode? Thank you in advance for your help
I had tried it ... when the computer is connected in USB on the table but not on VirtualDJ, the table remains in autonomous mode and there, the talkover works correctly and cuts or lowers the music according to the setting that I set and as soon as I launch VDJ, the connection is done,
I see on the skin (unfortunately not the one of the SC Live4 that I did not find in all the models proposed... I tried the skin of the denon prime4, but well it is not quite the same), I see almost all the manipulations that I make on the table work on the skin but on the other hand it disables the talkover...
A VDJ user says
Posted Tue 28 Mar 23 @ 10:48 am
