NortheastDJs wrote :
It doesn't.
Got Pioneer involved, they had me reset the audio / midi for the rev7's. Seems to have resolved the issue. On a Mac you go to Applications - Utilities - Audio Midi Setup
Set up a new configuration and delete the IAC driver. I've only tested one of the REV7's but the one I'm currently using is operating correctly
Did the fix work? Thank you!
Posted Fri 29 Dec 23 @ 2:09 am
