user18822178 wrote :
Don't know what you've done with the new update, (not mentioned in the changelog) but the Nvidia RTX3050ti 4 GB now works @ 11x speed! instead of 3-4 minutes before for a 5 minute track.
Fast enough for me to be workable with and faster then with the AMD Radeon!
So, good job guys!
So, good job guys!
Hi, can you share how to configure VDJ to achieve these results?
Posted Wed 17 Jan 24 @ 10:55 pm
update graphics driver and try again
Posted Wed 17 Jan 24 @ 11:43 pm
Still the same results. 1.3X.
do i need to change anything else?
Posted Thu 18 Jan 24 @ 7:42 pm
Then it's not RTX 2060, it's RTX 2050 and its dedicated VRAM is not high enough to handle Real-time Stems separation. Needs at least 6GB, yours is 4GB
https://virtualdj.com/wiki/Minimum%20system%20requirements.html
Posted Fri 19 Jan 24 @ 2:37 am
I understand the minimum specs required, but OP says he find a solution to make it through whit 4GB VRAM, so it's this possible whit RTX2050?
Posted Fri 19 Jan 24 @ 2:47 am
Indeed, works absolutely fine with 4GB for me. Go check out page 2 of this thread where I discuss the Windows Hardware Accelerated GPU settings. Changing that to force it to use the dedicated GPU (instead of the onboard graphics) solved my problem.
Posted Sat 20 Jan 24 @ 6:22 am
[/quote]Indeed, works absolutely fine with 4GB for me. Go check out page 2 of this thread where I discuss the Windows Hardware Accelerated GPU settings. Changing that to force it to use the dedicated GPU (instead of the onboard graphics) solved my problem.[/quote]
Sadly, this doesn't work for me either, please share NVidia driver version and VDj build to test correctly.
Posted Mon 22 Jan 24 @ 7:16 pm
Only 1.0 to 1.3Xcomputed speed achieved.
Posted Mon 22 Jan 24 @ 9:55 pm
after 3 windows installs, it seems problem was solved, already 10.x plus stems processing speed achieve. Also, 4gb VRAM in use, weird.
Posted Wed 24 Jan 24 @ 4:57 pm
Finally, it was fast enough to achieve 10x computing speeds.
Posted Wed 24 Jan 24 @ 5:37 pm
What did you do to achieve this?
Posted Wed 24 Jan 24 @ 8:47 pm
looks like you have to use this driver 551.23, (PhysX enabled) to achieve these results.
Last one driver i use doesn't work.
Posted Wed 24 Jan 24 @ 10:20 pm
