As the title says, every so often the software freezes when using hot ques and que loops. It's very strange and happens accross 3 different controlers. (Reloop touch, mixon 4, XDJ XZ). Has anyone run into this?
I have a hypothesis but i'm unsure if it's true or not. The more visual stuff I do it's more likely to freeze? But i'm unsure.
any ideas welcome
any ideas welcome
Posted Sat 25 Feb 23 @ 7:20 am
You say you have an M1 MacBook Pro. Need more details (see mine below).
I use an M1 MacBook Pro and don't experience any freezes.
My Systems Specs;
Main - M1 MacBook Pro (14-inch, 2022), Apple Silicon M1 Pro, 16gb, 500 gb SSD, macOS Ventura 13.2.1, VirtualDJ v2023-m b7469 (Early Access).
External WD Passport Ultra 2Tb HD formatted exFat containing Music & Video databases.
My Systems Specs;
Posted Sat 25 Feb 23 @ 7:44 am
Yes Macbook M1 pro
1 T Hard drive
16 GB Ram
Ventura 13.0.1
VDJ version: 2023-m 7462
1 T Hard drive
16 GB Ram
Ventura 13.0.1
Posted Sat 25 Feb 23 @ 7:55 am
Check this thread out that I answered recently for the same issue as yours. Watch my short video on how smooth the graphics are.
Look here
Look here
Posted Sat 25 Feb 23 @ 11:48 am
Thanks for the thread! i'll start with turning off pro motion, then tuning the FPS. I'll post my results after a deep dive. Cheers!
Posted Sat 25 Feb 23 @ 7:03 pm
Yeah along with everyone's answer, definitely the video side. Promotion and frame rates are the culprit.
Posted Sat 25 Feb 23 @ 9:38 pm
Yeh, I haven't turned off ProMotion on mine, I only set the videoFPS = 120 and you will of seen the results in my little demo video. :-)
Glad, it has been of help to you, it's always difficult to find the source of problems like this.
Posted Sat 25 Feb 23 @ 11:25 pm
