Hi I have the old vdj 8 in everything I set my hot ques and turn off computer my ho ques erase. I'm having a hard time erasing cues in poi keeping them arased
Posted Fri 13 Jan 23 @ 4:09 am
Cues are saved in the database, so if they're not saved, that means there's a problem writing to the database. Are your files on an external drive that you can't write to?
Posted Fri 13 Jan 23 @ 9:44 pm
