Right now with the Mixstream Pro when i load a deck the screen does not switch back to the decks screen.
Can some one help me out with this?
What I'd like is, when I press the load button for the screen to switch back to the deck screen and out of the library view.
Thank you!!
Thank you!!
Posted Thu 12 Jan 23 @ 10:49 pm
I think it's
set '$primebrowserextend' 0
so you could add to your keyboard onsongload mapping or your load mapping of your device
doubleclick ? clone_from_deck : load & set '$primebrowserextend' 0
Posted Thu 12 Jan 23 @ 11:16 pm
Thank you!!
I’ll try it out and let you know 🤙🏾
Posted Fri 13 Jan 23 @ 3:49 am
the SOUND INSURGENT wrote :
Thank you!!
Ok it worked!!
Now could you also make it so when I turn the browser knob it switches to the library view??
Appreciate yeah man!
Posted Fri 13 Jan 23 @ 3:53 am
browser_scroll & set '$primebrowserextend' 1
I wouldn't choose this as browser_scroll comes in for more than just the browser [like dropdown menus] but each to their own
Posted Fri 13 Jan 23 @ 3:57 am
Aah ok, that makes sense.
Posted Fri 13 Jan 23 @ 2:35 pm
