After I place a track into the stems for stem prep, and upload to any of the decks, there is no audio. I have to close VDJ8 and reset my DDJ-800 in order to reset and obtain audio. Any ideas?
Model Name: iMac
Model Identifier: iMac18,1
Processor Name: Dual-Core Intel Core i5
Processor Speed: 2.3 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 4 MB
Hyper-Threading Technology: Enabled
Memory: 8 GB
Graphics:
Intel Iris Plus Graphics 640:
Chipset Model: Intel Iris Plus Graphics 640
Type: GPU
Bus: Built-In
VRAM (Dynamic, Max): 1536 MB
Vendor: Intel
Device ID: 0x5926
Revision ID: 0x0006
Metal Family: Supported, Metal GPUFamily macOS 2
Memory:
Memory Slots:
ECC: Disabled
Upgradeable Memory: Yes
BANK 0/DIMM0:
Type: DDR4 SO-DIMM
Speed: 2133 MHz
Status: OK
Manufacturer: 0x802C
Part Number: 0x344154463531323634485A2D3247334532202020
Serial Number: 0x40194699
BANK 1/DIMM0:
Type: DDR4 SO-DIMM
Speed: 2133 MHz
Status: OK
Serial Number: 0x40194617
Model Name: iMac
L3 Cache: 4 MB
Memory: 8 GB
Graphics:
Type: GPU
Bus: Built-In
Vendor: Intel
Device ID: 0x5926
Revision ID: 0x0006
Memory:
Memory Slots:
ECC: Disabled
BANK 0/DIMM0:
Type: DDR4 SO-DIMM
Speed: 2133 MHz
Status: OK
BANK 1/DIMM0:
Type: DDR4 SO-DIMM
Speed: 2133 MHz
Status: OK
Posted Fri 30 Dec 22 @ 8:52 pm
