Topic: Midi map load not working....
Hi. I am trying to map a touchOSC template. Everything seems to be going well except the "load" function. I cannot get "Deck 1 load" to work. The button works as it should if I use "Deck 1 load_next". But I cannot map a button to load the selected song to either deck. The button works as described above, and I used it to test "unload" and it worked as well. I just cannot get the "load" command to work....?
Posted Thu 29 Dec 22 @ 2:02 am
Everything else seems to work using those buttons. Just the simple "load" will not work. My workaround for now is to use "Deck 1 browser_enter" and that will load the song that is selected on Deck 1. I have another button with the same for Deck 2 and seems to all be working as I hoped.
I deleted my request for checking the active deck. Things seem to be working as I have it above....
All good!
