So I have a set of LC6000’s paired up with a set of SC 5000m’s and everytime I start them up the lights on the buttons never light up until I press them.
The buttons never light up on the LC6000’s never light up until pressed.
So basically I have to go and press every button before I even start playing on them.
I use the power adapter that came with them so I don’t believe it’s a power issue.
Can y’all tell me what I need to be looking for or need to change??
I don’t have this issue with SDJ, it only happens with VDJ 🤦🏾♂️
Posted Mon 19 Dec 22 @ 8:05 pm
Was it always like that ?
Same if just the 2 LCs (no 5000Ms) ?
What if you goto Settings , right-click on an LC6000 and choose Reconnect ?
Posted Mon 19 Dec 22 @ 9:30 pm
As far back as I can remember it’s always done it, with it without the 5000’s …
I’ll make a video tonight and show you exactly what’s happening.
Posted Mon 19 Dec 22 @ 9:58 pm
Here’s the issue
Anything I should do differently??
Posted Mon 19 Dec 22 @ 11:50 pm
Weird huh!
Not a deal breaker for me but definitely annoying to say the least …..
Posted Tue 20 Dec 22 @ 5:57 pm
Have you connect the LC6000s direct to your MAC(USB HUB) or pluged in the SC5000m.
When you plugged in the SC please test with a direct connection to the MAC.
Posted Tue 20 Dec 22 @ 9:34 pm
I’ll try it again but I shouldn’t have to do that.
The hubs on the 5000m’s should be enough even with the power adapters.
I’ll report back in a few 🤙🏾
Posted Tue 20 Dec 22 @ 10:16 pm
Ok so I tried them into an Anker powered hub and whenever I select a deck all the lights go out.
What is wrong??
Again this doesn’t happen with SDJ….
What is wrong??
Posted Wed 21 Dec 22 @ 12:53 am
After u select the Deck on LCs, goto Settings, Mapping tab, right click on a LC6k and choose Reconnect.
Do leds light up or going back to Deck selection mode ?
Posted Wed 21 Dec 22 @ 1:37 am
Makes no difference
It’s like it’s losing the signal for some reason 🤷🏾♂️
Posted Wed 21 Dec 22 @ 1:54 am
