Hi, Using VDJ 7 all the cues saved. Using VDJ 2021 with up to date build, I can not get cues to save. All folders on PC have got full permissions. I have read lots in relation to this. When I click 'cue' in VDJ2021 it puts a little arrow in the waveform and does not save. If I go back to VDJ 7 and press 'cue' is shows cue in the waveform.
Any ideas?
Any ideas?
Posted Sun 20 Nov 22 @ 2:29 pm
Any ideas?
Any ideas?
Regular/temp cues are not supposed to safe.
Only hot cues are
v7 didn't respect that, and put temp cues in the first hot cue slot
Again, that is not really how it should be, but if you like it, maybe this will inspire you:
Posted Sun 20 Nov 22 @ 2:49 pm
