Forum: French Forum
Topic: [NEW] VirtualDJ 2023 avec Stems 2.0 - Page: 3
Bonjour,
c'est une vrai sonic ta config
Log Report.txt wrote :
--- 2023/01/26 - 11:48 (7388)
[11:48:08] Error in skin icon definition! (Icons file too small to fit all icons)
--- 2023/01/27 - 17:12 (7388)
[17:12:30] Stems engine error: 577/6
--- 2023/01/27 - 18:24 (7388)
[18:24:37] Stems engine error: 577/6
[18:24:37] stems engine GPU error, fallback to CPU
[18:54:05] Thread deck freezed.
--- 2023/01/27 - 19:47 (7388)
[19:47:34] Thread WASAPI freezed.
--- 2023/01/28 - 13:11 (7388)
[13:11:17] Stems engine error: 577/6
[13:11:17] Stems engine error: 577/1
[13:11:18] Stems engine error: 577/1
[13:11:19] Stems engine error: 577/1
[13:11:21] Stems engine error: 577/1
[13:11:22] Stems engine error: 577/1
[13:11:23] Stems engine error: 577/1
[13:11:25] Stems engine error: 577/1
[13:11:26] Stems engine error: 577/1
[13:11:27] Stems engine error: 577/1
[13:11:29] Stems engine error: 577/1
[13:11:30] Stems engine error: 577/1
[13:11:31] Stems engine error: 577/1
[13:11:33] Stems engine error: 577/1
[13:11:34] Stems engine error: 577/1
[13:13:20] Stems engine error: 577/1
[13:13:27] Stems engine error: 577/1
[13:13:27] stems engine GPU error, fallback to CPU
Encore une erreur, malgré le changement recommandé dans le fichier settings :
--- 2023/01/29 - 13:40 (7388)
[13:40:17] GPU speed: x2.2
[13:40:22] GPU speed: x2.4
[13:40:26] GPU speed: x2.5
[13:40:31] GPU speed: x2.5
[13:40:36] GPU speed: x2.5
[13:40:40] GPU speed: x2.5
[13:40:45] GPU speed: x2.5
[13:40:50] GPU speed: x2.5
[13:40:55] GPU speed: x2.5
[13:40:59] GPU speed: x2.5
[13:41:04] GPU speed: x2.5
[13:41:09] GPU speed: x2.6
[13:41:13] GPU speed: x2.6
[13:41:18] GPU speed: x2.6
[13:41:22] GPU speed: x2.6
[13:41:27] GPU speed: x2.5
[13:41:32] GPU speed: x2.5
[13:48:01] Stems engine error: 577/6
[13:48:01] Stems engine error: 577/1
[13:48:02] Stems engine error: 577/1
[13:48:03] Stems engine error: 577/1
[13:48:05] Stems engine error: 577/1
Ok merci (je n'ai pas dit que le changement dans les settings allait corriger le problème. Il donne plus d'informations pour l'analyse).
Le traitement avec le GPU tombe en erreur alors qu'il y a pourtant un resultat de x2.5 (pas top mais cela ne devrait pas tomber en erreur)
Et si tu selectionnes "don't use GPU"?
Adion wrote :
It looks like many 3050 Ti come with only 4GB memory, which is not enough, but if you find one with 6GB memory or more, then it will indeed be fast enough.
Adion wrote :
Djratedxxx919 wrote :
What about the rtx 3050 not ti just rtx 3050
If you find one with 6GB VRAM that should be fine too.
The memory usage also depends on the drivers, and therefore varies a bit per model/brand.
Basically, for GTX 4GB VRAM is needed, for RTX 6GB VRAM is needed.
Adion wrote :
It appears that by default more ram is used on the RTX 3000 series compared to the 1000/1600 series, which might explain why 4GB is enough for 1000/1600 but not for 3000.
We're still investigating to see if we can lower the memory use for RTX 3000 cards with 4GB ram.
Donc il faut que tu utilises ton cpu et non ton gpu pour l'instant.
Mes Chers amis. N ayant pas un ordinateur avec une carte graphique adaptée je pré calcule mes stems. Savez vous s il vous plaît où sont stockés les fichiers stems car mon disque dur interne risque d être saturé ?
Merci
Bonjour regarde a gauche dans VDJ il y a l'ongle "stems"
Je te remercie.
En fait je me suis mal exprimé. Sur le disque dur il y a un fichier stems? si oui j'aimerais le déplacer sur un ssd externe pour ne pas trop remplir mon ssd interne où se trouvent tous mes mp3.
Bonne journée à toi et bon mix à tous
Tu peut faire un raccourcit peut être
Sur le mien qui avais des ralentissement et des sautes d'humeur, j'ai décoché utilisation du gpu
Bravo la team
je suis en train de tester j'ai le sourire au max. C'est une dinguerie ces stems 2.0
Pour information, la carte graphique Nvidia RTX3050ti qui posait problème a cause de la faible valeur de VRAM (4GB) reagit mieux dans la derniere build 7533.
Il y a également de nouveaux details/statistics tres utiles dans le tooltip au niveau du cpu sur la skin (cela evite d'activer le fichier de log)
Bonjour a tous,
J'ai un PC portable peu puissant. Et un PC fixe avec une grosse CG et plein de cudas :)
J'aimerai savoir comment je pourrais faire le calcul de tous les stems sur le PC fixe, pour ensuite copier coller les fichiers sur le pc portable ?
Bonjour,
je voulais savoir si avec un i7 1165g7 et le GPU intégré Intel ruiju X les stems 2.0 peut fonctionner ou pas du tout ?
Merci
djforum wrote :
Bonjour a tous,
Après quelques test avec d'autres utilisateurs, pour que ça fonctionne il faut les deux fichiers (original en mp3/wave/flac) et les fichiers .stem)
Normalement cela doit fonctionner, à tester...
@DJ-Steph :
Fait des test mais je ne pense pas que cela fonctionne (en live c'est sur) par contre en scan, peut être, à tester.
En faite je cherche une tablette sous windows pour mes déplacements, je ne veut pas de PC portable car c'est trop gros surtout si je dois en prendre un avec une RTX 3070.
Pour le moment je n'ai rien acheté.
Je demandais si quelqu'un avait déjà essayer avec ce genre de combo CPU & GPU.
Même si les chansons sont scannés en 1min ça laisse de temps pour mixer
Merci Lylian !
Sais tu dans quel repertoire il faut mettre le stem ? dans le meme que celui du mp3 concerné ?
Bonjour DjForum,
Par défaut, les fichiers stems scannés sont placés avec les fichiers originaux (la meilleurs solution si tu bosse sur deux pc's différents)
Sinon sur la ligne stemSavedFolder sélectionnez un nouveau dossier ou seront sauvegardés les fichiers .stem.
Merci bien Lylian je vais tester :)
