Forum: VirtualDJ Plugins
Topic: Help with spout pluggin
So I have no idea how to set this up, There's a git hub page, I've downloaded every thing and put it in a folder and tried bott visualiser and video effects folders for virtual dj. But no luck, The git hub page says I should have VDJSpoutReceiver64.dll (I only want virtual dj to receiv video input) But that file doesn't seem to be on the page. Im very lost. Any one have this working for Vdj 2020 who can help me out?
Posted Mon 05 Sep 22 @ 8:31 pm
Sorry that the documentation is out of date. This is a direct link to the latest release:
https://github.com/leadedge/SpoutVDJ/releases/download/v2008/SpoutVDJ_V2008.zip
Unzip it and you will find Win32 and x64 folders. The x64 files are re-named.
Copy SpoutReceiver.dll to : Documents > VirtualDJ > Plugins64 > Visualisations
When you activate the plugin from within Virtual DJ, it will receive from the first Spout sender running.
Would Sprout be a "BETTER" option than NDI? Trying to send video/audio to a resolume computer. How does one physically set up the connection between computers? I there a "how to do it for dummies'" or Video somewhere? I have tried NDI but do not know if its correct. "NDI-Send" on VDJ computer and source to layer on resolume computer....Just using WiFi at home and playback in resolume software starts off good then audio is off (lags)??? I think I need a router or something ???
Thanks
If all you want to do is play video loops (Superheroes) on the VDJ sampler, you don't need to send anything to Resolume.
