Hi guys! asmensionned in the title, i can't swap left/right decks with my single controller Kontrol D2. It swaps only between sided decks ( B/D) .
According to the manual, i could "Cycle through all the available Decks when a single D2 device is connected" but not.
I'm using VirtualDj. I tried to modify the DECK button script by naming in parameter the "invert-controller" function with no result. Thx for any help !! ;)
Posted Fri 26 Aug 22 @ 12:31 am
i found my solution to this by modifying the "DECK" and "SHIFT_BECK" buttons script.
Instead of using the function "invert_controllers" (the default parameter), i use "assign_controller" . Like this "DECK 1 assign_controller "Traktor Kontrol D2"" for "DECK" script, and "DECK 2 assign_controller "Traktor Kontrol D2"".
So now i can swap Left / Right when i have only one D2 plugged in VDJ.
Vi ses ! ;)
Vi ses ! ;)
Posted Sat 27 Aug 22 @ 9:01 am
