Topic: Kontrol D2 Deck swapping Left/right no possible.
Hi guys! asmensionned in the title, i can't swap left/right decks with my single controller Kontrol D2. It swaps only between sided decks ( B/D) .
According to the manual, i could "Cycle through all the available Decks when a single D2 device is connected" but not.
I'm using VirtualDj. I tried to modify the DECK button script by naming in parameter the "invert-controller" function with no result. Thx for any help !! ;)
Posted Fri 26 Aug 22 @ 12:31 am
i found my solution to this by modifying the "DECK" and "SHIFT_BECK" buttons script.
Instead of using the function "invert_controllers" (the default parameter), i use "assign_controller" . Like this "DECK 1 assign_controller "Traktor Kontrol D2"" for "DECK" script, and "DECK 2 assign_controller "Traktor Kontrol D2"".
So now i can swap Left / Right when i have only one D2 plugged in VDJ.
Vi ses ! ;)
Posted Sat 27 Aug 22 @ 9:01 am
so this is not possible? it would be nice to be able control like traktor pressing "DECK" + top buttons "ABCD" and choose wich deck to control with one D2.
also would it be possible to have on D2 screen decks A&B instead of default A&C or B&D
thank you
Posted Sat 08 Jun 24 @ 5:32 pm
mapping for "DECK" key for switching between deck A & B
action_deck 1 ? deck 2 assign_controller : action_deck 2 ? deck 1 assign_controller
Posted Sun 09 Jun 24 @ 9:08 pm
