So I’m using a Denon X1800 and it has a knob for each channel that controls my sweep fx’s.
I don’t really use the hardware sweep fx’s to much, so I’d like them to control my COLOR FX’s.
How would I map the knobs to control that please?
Posted Mon 15 Aug 22 @ 10:05 pm
If i remember right this mixer operates entirely in hardware.
So while the crossfader etc moves in VirtualDJ, its all done in hardware.
So in theory you could map the sweep fx, but they would do sweep no matter what. And any color fx would be added on top if so
See here:
https://virtualdj.com/manuals/hardware/denon/x1800/controls.html
See here:
Posted Tue 16 Aug 22 @ 11:17 am
To map, simply start typing in sweep in the key field in VDJ mapper settings..
and them add the action : filter
But it would sound pretty terrible probably. Being a combination of hardware and software fx
Posted Tue 16 Aug 22 @ 11:19 am
Yup this is correct, none of the VDJ fx,s really work with this mixer.
Posted Tue 16 Aug 22 @ 12:10 pm
A small add-on unit might be something to consider.
https://virtualdj.com/products/hardware.html?category=addon
(although they are often more ideal for pads, less knobs. but some have)
Posted Tue 16 Aug 22 @ 1:01 pm
Yeah I have an SP1 and an XP1 laying around somewhere that I could probably put to work 🤙🏾
Thanks for the time and info,
Here’s my latest mix, give it a listen and let me know what ya think 👌🏾
https://www.mixcloud.com/soundinsurgent/this-is-for-my-rollers/
Posted Tue 16 Aug 22 @ 10:24 pm
