I need a little help to map the AKAI APC mini
I am halfway
I have try to modify the button on row 1 button number 5 to apply fx
ROW1_PAD5
yes, ok perfect... but now how do I specify that need to do only on the left deck or the decks number 1 and 3?
same for
LED_ROW1_PAD5
Yes, ok but become red any deck I turn on the fx so how to say turn on only if effect active 1 is on deck 1 or 3 or decks on the left?
I am halfway
ROW1_PAD5
effect_active 1
same for
LED_ROW1_PAD5
effect_active 1 ? color 'red' : color 'yellow' : off
Posted Mon 18 Jul 22 @ 11:54 am
add
Deck left or deck right
to the front of the line
Posted Mon 18 Jul 22 @ 12:01 pm
i have already tryed
and
I tried also
and
and
and
NOT WORKING! I mean is working but on master not on left or right...
probably I need another script
deck left effect_active 1
and
deckleft effect_active 1
I tried also
deck left : effect_active 1
and
deckleft : effect_active 1
and
effect_active 1 : deck left
and
effect_active 1 : deckleft
Posted Mon 18 Jul 22 @ 1:19 pm
If I remember right when I adjusted the mapping for mine it was defined as one deck. you will need to change that to 2 or 4 decks. It's at the top of the mapping. Can't remember the exact code. If you can't find it I can look when I get home from work.
Posted Mon 18 Jul 22 @ 3:00 pm
on the top there is for the ddj 400 automatic (left, right)
for the akay there is Automatic (default)
Posted Mon 18 Jul 22 @ 6:27 pm
sorry i see i never changed mine and deck left and right commands are working fine
have you tried with deck 1 ?
or deck 2?
or deck 2?
Posted Mon 18 Jul 22 @ 7:10 pm
if i put deck 1 on the top work only for deck 1 the akay
Posted Mon 18 Jul 22 @ 7:55 pm
your first try (and suggested by WickedMix) should have worked
Tested:
and
work when tried in skin custom button, on button of LaunchPad and on MidiFighterTwister. (don't have AKAI APC mini, to test)
and as WickedMix has suggested .. specifying the decks with deck 1 deck 2 etc will also work.
Tested:
deck right effect_active 1
and
Posted Mon 18 Jul 22 @ 8:01 pm
Yeah... i don't know why now is working .... But thanks very much everybody!
Posted Mon 18 Jul 22 @ 8:34 pm
