Topic: Audio issues
As soon as I open VDJ, I can no longer get audio from my desktop. After I close VDJ and try audio again I get an "Audio renderer error. Please restart your computer." message. Please help
Posted Fri 01 Jul 22 @ 4:27 pm
same for me
Which version/build of VirtualDJ do you use?
PC / Mac ?
Do you use a controller?
Which audio card do you use?
ASIO/Wasapi/CoreAudio?
Can you post a screenshot of your AudioSettings in VirtualDJ?
PC
No controller
Audio Card - High Definition audio Device
Generally, when DJs run their DJ software, they want the audio from the DJ software - and ONLY from the DJ software. That's normal operation.
