Hey! I might need some help.
Here's the deal - I got a new DJ deck - Numark Mixtrack Pro FX.
The problem is when I open the VDJ software and start mixing the crossfader and the volume faders won't function. They are detected from the program as I see them moving when I also move them from the controller. But during a song - nothing.
Thanks in advance!
Thanks in advance!
Posted Mon 07 Mar 22 @ 1:07 am
Perhaps you have wrong audio setup
See here
https://www.virtualdj.com/manuals/hardware/numark/mixtrackprofx/setup.html
And check in VirtualDJ audio settings, if all looks correct
See here
Posted Mon 07 Mar 22 @ 11:20 am
I checked and everything seems to look fine but still no result
Posted Mon 07 Mar 22 @ 5:23 pm
still need help tho
Posted Tue 08 Mar 22 @ 7:09 pm
what is your current audio setup?
and a screenshot perhaps?
and its all faders or only the crossfader?
Posted Tue 08 Mar 22 @ 7:55 pm
The problem is with the crossfader and the volume faders.
I can't seem to find an option for photo uploads, so I'd be also thankful if you give me some coordination about that as well.
about the audio setup - on outputs, the master is on channels 1&2 and the headphones are on channels 3&4
I'd gladly upload more screenshots if this information is not helpful
Posted Wed 09 Mar 22 @ 1:46 am
That seems correct (without me having that controller).
But the most common audio setup for entry / mid range controller is master + headphones, as you have set it.
Posted Wed 09 Mar 22 @ 6:47 am
Just to ask. You do hear the music right?
And the speakers are connected to the Platinum FX?
And try install the firmware update for this controller
https://www.numark.com/product/mixtrack-platinum-fx
Posted Wed 09 Mar 22 @ 6:49 am
yes, I do hear music.
I installed the firmware for the controller from the link above but still no result
Posted Thu 10 Mar 22 @ 2:28 am
Hmm strange. If you have audio AND you see volume fader and crossfader move in the software.
Can you paste and upload image of your sound settings here:
https://pasteboard.co/
Although from what you said, it sounds correct already..
But maybe you inverted headphones and master. If so you could always try the headphone volume knob on the controller, and see if that lowers the speaker volume. But maybe not likely, worth a check ..
Posted Thu 10 Mar 22 @ 7:03 am
Posted Thu 10 Mar 22 @ 10:19 am
your audio config is not applied
Posted Thu 10 Mar 22 @ 10:41 am
Did you just change for the screenshot? Those sound settings are not really in use (yet)
Posted Thu 10 Mar 22 @ 11:18 am
And if you get an error after you press "Apply",. it might be because the sound card on the controller is already in use (elsewhere), most likely as Windows default sound card if so.
Set it so that Windows does not use the controller as playback nor recording device
https://winaero.com/change-default-audio-device-windows-10/
Posted Thu 10 Mar 22 @ 11:19 am
