Qdo sai a nova configuração atualizando esse problema com as rane 72 e twelve pra poder usar o virtual dj????
Posted Wed 16 Mar 22 @ 9:28 am
the SOUND INSURGENT wrote :
Got an ETA?
Really wanna use this setup this weekend, pleeeeeeeeeease🙏🏾
Latest EA build (released a couple of hours ago) should have your fix included
Posted Wed 16 Mar 22 @ 3:45 pm
Thank you!!
Will try it out and report back when I get home tonight 🤙🏾
Posted Wed 16 Mar 22 @ 4:22 pm
Been playing around for a few hours now and only had 1 odd crash. VDJ did restart but it’s been all good since then.
Maybe if someone can look up the crash report please.
Posted Thu 17 Mar 22 @ 2:48 am
It looks like the crash happened when one of the decks disconnected, will fix.
Posted Thu 17 Mar 22 @ 2:57 am
Thank you and I really appreciate all the behind the scenes efforts here.
One other question, I should also be able to use my Denon SC 5000m’s in the same way, correct?
Posted Thu 17 Mar 22 @ 3:13 am
Yes
Posted Thu 17 Mar 22 @ 3:25 am
Y’all have just made my night!!
Thanks again!!
Thanks again!!
Posted Thu 17 Mar 22 @ 3:34 am
i know this is old topic but im having this exact problem but we both using pc's .
whenever my partner comes to gig with me i let him connect and then i cant dj any more due to ost control over the rane 12
Posted Mon 29 Jan 24 @ 11:36 pm
I'm pretty sure you don't have the EXACT same issue as it has been fixed for quite some time now.
Unless you use a quite old version of VirtualDJ.
So, please explain to us your issue as best as possible.
The more details you are able to provide to us, the better.
Otherwise we cannot help you since as far as we know there are no known issues with those devices, and most likely your issue is either system specific, or user case specific.
Posted Tue 30 Jan 24 @ 9:03 am
