I want to use the buttons Pitch Bend - and + buttons for 'goto -4' and 'goto +4' functions.
After setup of above mapping, Pitch Bend - (goto -4) button works, when the song plays, it skips to beats before.
When I press Pitch Bend + (goto +4) nothing happens.
When I give this button another function, it works, except goto +4!
Alternatively I used another button I never use (CENSOR) for goto +4 and this works, the song skipt to 4 beat furhter.
Any idea why I can't set the Pitch Bend + button for goto +4 function?
Posted Tue 01 Feb 22 @ 6:40 pm
I cannot reproduce that, on my Denon MC7000.
I added goto +4 on the BEND+ , mapping and pressing the Bend+ button, moves correctly, the position in the track 4 beats forward for every press.. (tested on all 4 decks)
Let me know if there is something else, I can test/try.
Have you tried,
1) another USB cable, or
2) with the default Denon MC7000 Mapping with just that one change,
3) and checked in the mapping window. or with midi-ox that the button is sending good midi
4) and assume your computer has been purchased recently.. and easily capable of running stems.. ask since there is a firmware setting that allows one to increase or decrease the MIDI Command Transmission Interval Time. (default is 4ms) can be set between 1ms and 14ms.
using win 10
VDJ 6800
and the latest drivers and firmware from Denon (note: there have not been updates recently)
Have you tried,
using win 10
VDJ 6800
Posted Wed 02 Feb 22 @ 2:56 pm
@IIDEEJAYII, thanks for your ideas.
1) As all other functions working fine, I didn't try with any other cable
2) Loaded the default MC7000 mapping and only changed the Pitch Bend - and + and it worked!
Thanks to solve my problem ;-)
I guess the mapping somewhere, somehow became corrupt. By starting from the default one, it worked.
Thanks, once more!
Thanks, once more!
Posted Thu 03 Feb 22 @ 6:12 pm
