Hello. I purchased 2 sound cards. One tor the main audio and the other for cueing up.
Problem is, although the headphone volume is satisfactory, I need it to be louder. Is there anything I can do to achieve this ? I've played with the settings and all appears to be on max. They are both usb sound cards and my main output volume is lower than the main sound card built in
The sound cards are creative sound blaster play 3.
Posted Mon 17 Jan 22 @ 5:44 pm
To be honest, for DJing purposes you really should invest in an audio interface designed for the job.
Using two separate interfaces is never ideal, but something aimed at domestic/consumer use is not going to give you the kind of levels needed for DJing.
Posted Mon 17 Jan 22 @ 6:24 pm
Thanks . Could you recommend me something to get me started then I'll have a look around it please.
Posted Mon 17 Jan 22 @ 6:31 pm
maybe with "headphone amplifier" or "Headphones with an amplifier"
Most controllers have built-in headphone amplifiers.
a normal sound card has less of that
Posted Mon 17 Jan 22 @ 11:18 pm
