just downloaded the free version of VirtualDy, as my new Mac has rendered my Mixmiester Fusion useless due to it being 64bit... oh well...:-(
So I do Mixcloud mixes of soul music, all on 45 & LP, which I digitise and dove tail end in, no beat mixing, I just use my ear to make it a great show. I also speak over the mixes, back announce tracks and all that... So I really dont need to Virtual Dj to do much, However...
I need to configre my Mic, which doesnt seem to be working, and I just need to set this up to do the above easily...
Any help greatfully recieved.
Cheers all, Ma.C
Cheers all, Ma.C
Posted Mon 06 Dec 21 @ 10:24 pm
Details please. What mic are you using, how & where is it connected? What other equipment (if any) are you using - i.e. controller, audio interface?
Posted Mon 06 Dec 21 @ 10:35 pm
Rode NT-USB Mic plugged into a Mac (BigSur) 11.1
I dont have a controller, I dont know what that is mate, is what i have above enough to create what I have outlined?
have gone to audio settings, this is what Ive done, I cannot get my voice to register at all.
Outputs
Master - Rode In Chan 1&2
Headphones - iMac Speakers Chan 3&4
Inputs
Mic- Rode In Chan 1&2
Cheers
mal
Outputs
Inputs
Cheers
mal
Posted Mon 06 Dec 21 @ 11:13 pm
You're sending the VDJ master output to the Rode?
The mic is an input, not an output. The master needs to feed your speakers.
Ideally you need a second audio interface for cueing (the headphone signal).
Posted Tue 07 Dec 21 @ 6:26 pm
