I dont know why but the audio is constantly cracking. I'm not at the maximum volume either. I think it is the sample rate but its not updating when i change it in virtual dj. I am using a numark nvii. I have a quad core, 16gb of ram, 1tb hard drive and virtual dj is the only thing open. Please help.
Posted Sat 13 Nov 21 @ 2:53 am
Asio settings.
Posted Sat 13 Nov 21 @ 5:22 am
I found the adios settings, do you have any recommendations on how to find the right buffer?
Posted Sat 13 Nov 21 @ 4:52 pm
It's ASIO not adios, and the correct setting is the one that cures the problem.
What was it set to when you had the crackling? Increase it until the crackling stops.
Posted Sat 13 Nov 21 @ 8:04 pm
My bad it was autocorrect on my phone. I meant to put asio. Originally it was at 512, then I lowered it to 256. Now I’m going to try to bring it higher.
Posted Sat 13 Nov 21 @ 10:11 pm
