Adion wrote :
It is not VirtualDJ that creates these other files.
If you're on mac and you have your Documents folder syncronized with iCloud it's possible that it's unable to synchronize the changes with a database.xml on another computer causing it to create these numbered files.
I am on a Mac and use both iCloud and Dropbox, I'll try and stop syncing that folder and see if that works!
Posted Thu 18 Nov 21 @ 4:20 pm
My music folder is inside my dropbox folder but I have my Dropbox Sync turned off, maybe that is the issue, perhaps I should turn that back on? I will try that.
Posted Thu 18 Nov 21 @ 4:27 pm
It's Fixed! so just for anyone that has issues of multiple Database.xml files being created resulting in their database not saving and loading properly.....
I'm running a MAC and was connected to the iCloud. Look at your original Database.xml file and see if there is an iCloud Icon next to it, if there is, try pressing it, it fixed my problem and everything working as it should now :)
Posted Fri 19 Nov 21 @ 3:38 pm
Must Thank Adion for putting me on the right track!!! Thank you 😊
Posted Fri 19 Nov 21 @ 3:45 pm
