I recently updated vdj. The "echo out" effect that i had downloaded was kicked out. I looked at all the effects on the site and there is no "echo out" now. Is there a way to re-download it? Is there another echo effect on the site that is similar to "echo out"??
Posted Sun 19 Sep 21 @ 2:36 pm
No need for multiple topics.
https://www.virtualdj.com/forums/243179/VirtualDJ_Technical_Support/echo_out_effect.html
The Echo Out effect is still available through the extensions tab in VirtualDJ.
If it's not showing, make sure you updated to the latest version.
Posted Sun 19 Sep 21 @ 2:45 pm
